A Universal Port device-detect configuration requires only a switch and
supplicants. If
PoE devices will connect to the switch, the
switch should support PoE. Supplicants should support
LLDP in the applicable software or
firmware.
To support supplicant configuration, you might consider adding a
DHCP
server to your network.
Use the following procedure to
configure Universal Port for device detection:
